adding 2 remotes to an 820 3 cylinder diesel
Randya20
I want to add 2 remotes. Has any one added 2 remotes to an 820 3 cylinder diesel tractor, mine does not have any remotes, but has 3 point, Where would you tie into the hydraulics?
From the factory the early 820's only had one way sigle hyd hook ups. Local dealer said he would order them without and then mount an aftermarket valve (like a loader valve) on them to give two way hyds. You could do the same thing just get a two spool valve. Tom
Keep in mind that a JD 820 has open-center hyd system. Double acting valves & breakaway couplers are listed in 820 parts catalog.This is the way a FEL valve is attached to 820 hyd system.
So you want a Pair of SCV’s on the back for a log splitter etc . Then a dedicated hydraulic supply and return for a loader’s joystick ?
