JD 2550 Fuel Pump
No there is a small access plate on the timing cover to allow you disconnect the pump drive shaft from gear. The small plate is behind the lower radiator hose
I thought the fuel pump only cost $25 to $35. I guess if you can replace a couple o rings with out much trouble then it would be worth it.
