John deere 60 changing points/condenser
I bought the heavy duty point set from Napa Part # CS763A and there's like an extra spring on the end with the brass strip that attaches to the terminal in the distributor.Where does the end of this spring go? My original point set just had the brass strip.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto5217.jpg"/>
Those NAPA points are far superior to the cheap ones sold at Rural King and Tractor Supply etc. The spring provides good surface contact while the brass/copper looking one provides great electrical conductivity. The two mate up where the regular post/terminal is, you can easily tell and figure it out once you mount them.
John T
Thanks,John T.... I brought in the old set and compared them,that's when I noticed the difference...The 60 is twenty miles away,I just want to make sure they're the right ones.
