John Deere G head thickness and M&W piston dimensions?
kwoods
Does someone know the thickness of a styled G head? (F551R)
Also, what is the distance from the center of the wrist pin to the top of an M&W high compression piston? (.125" over)
Piston: http://www.external_link.com/mm5/merchant.mvc?Screen=PROD&Store_Code=oldjd4u&Product_Code=G791&Category_Code=73
My dad had the head decked around 20 years ago and can't remember by how much. I just measured the head and it is 5.56" from the valve cover surface to the block surface. I want to have the block bored and put these pistons in this winter and I'm trying to see if I'll have valve clearance issues before I get too carried away.
Any help is appreciated.
It also seems that the bodies of my other posts weren't showing up because I previewed my post before submitting
Your previous posts (and this one) do not show in Modern View because you included an external link with a vendor name that is censored in this forum when in Modern View. It has nothing to do with whether or not you previewed your post.
You are getting replies from people who use the Classic View. It does not censor the vendor names.
Try it again without the URL.
Your previous posts (and this one) do not show in Modern View because you included a link with a vendor name that is censored in this forum when in Modern View. It has nothing to do with whether or not you previewed your post.
unless you have a set of m&w pistons for that g you may never get one as M&w does not make anything any more.the new pistons you get now do not have as tall of head on them
Anybody on the original head thickness?? Also, this is measured from one gasket surface to another correct?
