8760 hyd pump
jdjerry
I just got around to getting the rebuilt hydraulic pump in my 8760. I started it up and let it run for a little bit and when I got in the cab again the stop light was on and no pressure light for axle lube was on. It was getting dark so I stopped then. Any ideas of what is wrong.
I did drop the old pump out the bottom and might have pinched something.
The stop light went of now and I had to add 5 more gallons to fill it. I drove over to hook it on the disc and now I have no hydraulics.
Hmmm...I do know that it's possible to plug the two speed shift solenoid wire to the pump de-stroking solenoid...then when you shift into high the pump quits!
