Mogster
So I ordered hydraulic couplers for it about 5 months ago. I ordered JDS 426. So today I went to install them. I ordered the wrong ones. The ones I need are JDS427, these are 56.50 each. Anyone have two old ones? But now I know there are two styles lol.
Here
<image src="http://forums.yesterdaystractors.com/photos/mvphoto5083.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto5084.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto5085.jpg"/>
It almost looks like your old one is the type a cap comes off and you can adjust it for rockshaft or side mounted quick couplers added. Photos a bit blurry for me to see for sure.
The part you have in your hand is called a plug, or sometimes referred to as a "dummy" plug.
a176177.jpg" width="650"
The plug comes as standard equipment with every Powr-Trol.
If you want to use a remote hydraulic cylinder(s), then you will need at least one or maybe two [b:654c4848f0]oil couplings[/b:654c4848f0] depending on the implement.
Take a look at the photos below of the oil coupling.
a176178.jpg" width="650"
Note that this oil coupling has a hex head that is threaded inside.
It is open at the other end.
a176179.jpg" width="650"
The open end allows the oil to flow through the Powr-Trol pump to and from the remote cylinder(s).
a176180.jpg" width="650"
Hope this helps.
I was hoping someone might have two of the lever style hydraulic couplers,and maybe trade for the treated style coupler.
Thank you but no those are the threaded style. I need the ones without threads and have a wide groove and shorter tube.
Steiner said I can return them. I was just hoping for a used set, after my screw up. I have had great service from Here (Yestetdays tractor) and Steiner. The problems been me (oh darn).
