Here's the 4055 I have been working on:
New cab liner from Fehr.
Replaced ALL fluids and filters.
Flushed coolant system.
New roof.
New LED Warning lights.
New LED front lights.
New LED inner fender lights for high beam.
Resealed and bushed front axle. (Had experienced help.)
Pressure washed radiator.
New main pump coupler.
Repaired almost wore through fuel line.
Replaced blinker indicator bulb.
Polished all sheet metal. It was really yellow-gray.
Cleaned cab roof top.
Cleaned Evaporator and Condenser.
New JD left step kit.
Custom made right step kit, not on yet.
Relocated tool box.
New door latch.
All new door weather stripping.
Replaced rear flood light.
Repainted nose and a few other spots.
Replaced blinker switch.
New antenna.
Cleaned floor matt.
Re-upholstered seat (by others) and installed new are rests.
All new foam around radiator side grills.
I learned a lot.
Well, I delivered it to my friend. He cut hay at night only to find out the back lights on the dash don't work. Oh well.
Paul
New roof.
Relocated tool box.
New door latch.
New antenna.
Cleaned floor matt.
I learned a lot.
Paul
