Forgot the timing cover drain (70D)
DrCharles
I just realized when I changed the oil & filter on my 70D that I forgot the timing cover drain plug...
How much oil gets trapped in there? If I take that drain plug out now, will all my new oil come out or just what's in the timing cover? Or just leave it until the next time I change it?
thanks
Charles
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">If I take that drain plug out now, will all my new oil come out or just what's in the timing cover?[/i:654c4848f0][/b:654c4848f0]</font>"
Probably "[i:654c4848f0]just what's in the timing cover"[/i:654c4848f0].
Take a look at the [b:654c4848f0]Cross-Section of Powr-Trol Pump[/b:654c4848f0] illustration below.
a176122.jpg" width="650"
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Or just leave it until the next time I change it?[/i:654c4848f0][/b:654c4848f0]</font>"
No harm to just leave it until the next time you change it.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">How much oil gets trapped in there?[/i:654c4848f0][/b:654c4848f0]</font>"
Nest time you might consider removing the timing gear drain plug before draining the crankcase.
Measure the amount of oil drained from the timing gear cover.
Next time maybe I will remember to do the same just for future reference.
Hope this helps.
After the tractor has set for a day or two you might want to crack that drain plug and let out any moisture that has settled.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">do you fill that or does oil get slung up there?[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the [b:654c4848f0]FLYWHEEL, FLYWHEEL COVER, AND TIMING GEAR HOUSING[/b:654c4848f0] diagram below.
a176154.jpg" width="650"
Note the timing gear housing (Key 21).
There is not a fill plug for the housing.
Take a look at the [b:654c4848f0]Cut-Away View of Oil Filter and Oil Lines[/b:654c4848f0] illustration below.
a176155.jpg" width="650"
Note the LH main bearing oil pipe.
Pure speculation on my part, but oil may come from the lubrication of the LH main bearing.
Hope this helps.
