JD 755 Sleeved?
Ditto to that. I have a '96 JD855 with MFWD. 21 years old and other than routine maintenance, the only trouble I've had with it is that a cotter pin in the joy stick linkage wore through and one of the oil lines to the oil cooler rubbed against the frame and wore through. (Had I spotted it, a zip-tie would have avoided that.) There's no drain in the bottom of the fuel tank so I recommend every year or so siphoning out from the very bottom of the tank what condensate may have accumulated. Two speed ranges behind the hydro and both mid- and rear- independent ptos that can be run. or not, in any combination are great features. Diff lock, independent wheel brakes too! Very stingy on fuel. What's not to like?
I use it on a front loader, 72" belly mower, 60" front snow blower, 60" roto-tiller, 12' 3-point/pto sprayer, 6' rear blade, etc. I hang about 900 lb of cast iron weights on the 3-point when using the loader or snow thrower, and then around 200 lb on the front when using the sprayer with 50 gal tank.
