620 air noise from valve cover ?
dmiller
620 making an air noise, appears to be coming from a leak in the valve cover? Sounds just like my A used to when I left the pet cocks open. Seems like an odd noise for a valve cover leak, seems odd that there is compression there? I know it needs a valve cover, but can't really explain the air noise (you can put your hand up there and feel it too).
Ideas?
Are you sure it's not an exhaust leak?
Do you feel any air out the breather tube?
If it's building that much pressure in valve cover there must be severe blow-by.
Sounds like way too much blow by. Those series have thin rings and I have seen several with broken top piston rings. But usually by the time it takes to do this the cyl. bores are worn enough they need rebored anyhow.
