Hey guys , so this is what I am up to. The governor shaft on the br does not sit horizontal when I have the flywheel timing mark aligned with the mark on the tractor . the slot in the governor shaft is tipped back a bit so when the magneto is rotated back it will not trip the impulse. To trip the mag I need to roll the flywheel ahead slightly ( with the mag rotated all the way counterclockwise ) . the tractor still starts (by hand) and runs but I would like the timing set correctly. So if I unbolt the left side governor cover will I be able to lift the shaft enough to unmesh the governor gear from the can gear to time them correctly so the magneto slot is horizontal with the flywheel timing mark lined up ? Thanks
