Does a 4760 power-shift have an engagement over ride valve in the shift valve?
A neighbor's tractor stopped moving on him...as in he stopped and filled his drill and now the tractor doesn't move.
Seems like in the past I had seen 50 series power-shift tractors with stuck over-ride valves(keep a farmer from running over himself)...anyhow..it's been so long since I've jacked with a 50/60 series power-shift I don't recall where the engagement over-ride valve is!!!
I had him hold the clutch down and start it..check the trans-disconnect..fluid level...etc....I'm going to have to go stick gages on it I guess
