2020 JD injector line
Mtractor
I just bought a 2020 JD tractor and one of the steel injector lines has a pin hole in it and is squirting pretty good. It's close to the injector pump. Can that be took of and brazed? Or JB weld? If not where can I get one? A good salvage yard?
You can braze even the injectors lines. It is less than 3000PSI. But you have to be good at it.
Do not [b:f74ee69d9d]ever[/b:f74ee69d9d] put your finger where the fuel leaks to stop it.
Try brazing it. What have you got to loose? If it still leaks start calling salvage yards. Make sure to tell them which injection pump you have as a few 2020's had the small injection pump otherwise the line could come off a 202,219 or 239 engine which were used in 100's of different applications. Make sure to clean up the pump good before removing the line. Tom
