While trying to adjust the brakes on my 70D today, the right adjuster screw was free so I set that one no problem.
But the left adjuster is frozen. Rather than risk breaking it off, I figured I'd just take off the brake drum and apply Acetone/ATF to the threads until it can be turned... except that the drum won't come off the pinion splines!
I backed off the nut to the end of the threads, braced the edge of the drum with an 8 lb hammer, and banged on the nut without success. Now I need a new nut and the drum is still stuck fast on the splines.
I suppose the next step is removing the brake assembly from the tractor. Only three bolts, let's hope I can move THOSE. Sigh.
Unless someone has a "never fails" trick for getting the drum to pop loose?
thanks
Charles
thanks
Charles
