Undersized clutch driver
36 A
Dose anybody make undersized clutch drivers ? I just did a quick look and Mike m was in a post and that didn't sound like they were any better then stock part . I'm planning on liking into it a little more tonight .
The ones I see advertised were for later pressed frame A's. And from my experience I could not measure anything on them that was different or "undersized" compared to a standard aftermarket part which was ALOT less money. Truly would be nice if they actually were undersized. ( legal disclaimer ) Your experience may vary. If you do get one measure it, compare it, and report back.
On a 2cyl. it is the center part of the clutch that is splined and fits onto the crankshaft. On a model A ,which is all I have ever seen undersized ones advertised for, it also acts as a balance weight too.
Well I'm guessing it's change the crank time , but think I found a parts tractor so well see this weekend . Thanks for the replies
