JD style fan assy. NLA. I used the aftermarket one, made in Tiawan. It has 2 sealed bearings &
cost about $50 several years ago. My M is a collector tractor which has not had over 100 hrs on it
since restoration. The fan assy has now failed. I have been unable to get it apart to replace
bearings. Seems like simple construction, hub pressed onto shaft with one nut to hold together. I
ended up buying a new one (from YT) for about $70. Has anyone else tried to get one of these apart
or would share your experience with same? KB TIA for any responses.
