Spindle bearings for JD 420W
WNYBill
I have found them on Amazon, however the needle bearings are 47.97 each and it takes 2. There has to be aftermarket bearings available The JD part number is JD8407 thrust bearing and JD8820 needle bearing.
I am unable to find a cross reference or a drawing with dimensions.
HELP
After searching the web I found the bearings at Waltstractor.com , but they don't have the seals and retainers, they have a M prefix in the service manual. M1518, M2282, M2283. I am going to call a JD dealer. Any other suggestions?
Thanks,
Bill
Do you have a bearing supplier around like Motion Industries? If you take the old bearing in they do not care what it came off of. They just match the bearing up.
i picked up two for an antique garden tiller just yesterday.
Usually takes one day to get. Same with seals.
(quoted from post at 22:17:08 10/11/17) I have found them on Amazon, however the needle bearings are 47.97 each and it takes 2. There has to be aftermarket bearings available The JD part number is JD8407 thrust bearing and JD8820 needle bearing.
HELP
JD8407 = Timken T139
JD8820 = Koyo B2220 or Torrington B2220
These items (seals / retainers) are avalible from Deere and are resonalbe priced.
Make sure that you include the "T" at the end of the part numbers
