50 B, Upper Rad Hose Size? Air intake hose?
Ayr Time
What are the actual dimensions (ID and length) of the upper rad. hose of the 50 B part no. A446R?
Also need dimensions for hose on the air intake part no. B2372R.
Thanks.
A446R is 6" long with a 2-7/8" ID and 3-1/4" OD.
You may need a longer hose if someone has cut off the upper water pipe because of rust.
B2372R is 4" long with 2-1/8" ID and 2-1/2" OD.
Thanks for the very prompt reply! This info is very much appreciated! I'm currently visiting Lancaster Pa. from Ontario. I see your nearby in Md!
Yes, I live in MD. Lancaster County is one of my favorite areas.
Try a good NAPA store. They might cut what you need from stock 3' sticks. Mine did for me years ago and only charged for the pieces I needed and didn't charge for cutting.
No luck at 2 NAPA stores.
I give high recommendation to Martin (classic JD) Parts and Repair, 1634 Valley Rd, Christiana, PA 17509. [email protected]
Phone:610-593-1010. Salvage yard and new parts. Joel cut me a piece of 2 7/8 coolant hose and had a new air intake hose, both for reasonable price!
