jeffbledsoe
New User
I have a 1963 john deere 4010, that i have been using to pull a hayrack wagon with about 20 people in it. It worked great all day, for about 7 hours, then pulling up to the drop off, i lost the brakes, power steering. After unloading the customers, i also checked the 3 point, no lift. So today I drained all the hydraulic fluid, changed the filter, checked the long sceen that is close to the filter. Fluid was very clean, sceen was clean. Filled up and started, no pressure. Cranked down the destroker valve, and then back up 3 times, no good. The input shaft for the pump is turning, I can see about 1 inch of it and it spins with the coupler. Cannot hear any pump sound at all. Not sure where to go from here. Any help would be appreciated. Thanks
