I started my 60 for the first time in a couple of years and it started right up with an oil pressure of about 20 psi. I noticed that after it warmed up, the oil pressure started slowly drop until is was hovering at about 4 to 5 lbs. I changed the oil to 15-40 rotella and put in a new filter and it still did the same thing.
I tried turning in the adjusting screw , and I can see the pressure move on the gage, but only in first minutes after the tractor is started. After it is warmed up, no matter how much I turn in the adjusting screw, the pressure doesn't change and hovers at 4 to 5 pounds.
What could be the problem?
