(quoted from post at 11:12:05 02/03/17) Your not going to find room to put a chain drive on a 5020 differential drive shaft,,just saying...when you go to modifying a transmission to gain power to drive a MFWD axle you are looking at a serious project, matching the ratio is a big deal in itself..putting old sheet metal on a newer unit is easy, bringing power out of an old transmission case puts the difficulty level much higher...
ey fdt860 if you any of the tin off the 760a or steel hyd lines . I'd be interested in them $$ .I'm trying to fix up 760a. I like your project.keep us posted how it's coming good luck.(quoted from post at 23:50:20 02/04/17)
