I know this is really basic but I'm in a time crunch that a quick answer will help. I have the manuals but can't find the information in them
I have to pull the front wheel off my 68 JD 2020 to get the tube and tire replaced. I got it jacked up and removed the large and small bolts in the rim. I can't get the rim loose as sometimes happen with corrosion and time. Before I go to the hammer or bar and beat it loose I want to be certain that it isn't one of those Wheels where you have to pull the cotter pin, nut and bearings to remove it.
