styled ar hydralics
grampsh1
I just purchased hydraulic tower for my 51 ar and need to know where hydraulic lines to reservoir tie in to chasis as no piping with it. I'm guessing will need to install a pump in transmission rear end housing that drives off pto shaft. Thanks for your help.
Paul
(quoted from post at 18:41:57 10/03/17) Didn't the AR have the governor-mounted pump?
that is quite possible been looking in jdparts catalog but not clear where pump mounts
(quoted from post at 20:47:53 10/03/17) Left side of the governor housing.
hanks Mike now I need to find a pump I gather the distributor came off pump went on distributor back on probably timing marks on pump for distributor and the tubing likely steel above or below floor board up under battery box to pump
Paul
Pictures of a couple of my JD STYLED AR's:
You could purchase a JD HYDRAULIC PUMP that attached between the MAG/Distributor and the MG/Distributor drive:
Bob...
thanks for pictures really appreciate
(quoted from post at 10:20:04 10/04/17) Pictures of a couple of my JD STYLED AR's:
Bob...
