John Deere 40 shift lever
ILB
A while back I stated that my John Deere 40 had a shift lever that was real sloppy. Someone suggested I change the original shift leer to a 420 tower-gated top. I did, but now it growls in reverse and 2nd gear. They are on top and bottom of each other in the tower. The other gears are quiet. What make them growl in reverse and 2nd gear. It is worse in reverse gear. Thanks for any and all help.
Are you sure the noise is new ?
I'd take the top back off for a look. Compare it close to the old shifter. See if perhaps one of the forks is bent or something ? I'd also see if you can feel for any loose bearings on the shafts.
