Now that my 50 is running (quietly) again, it's time to revisit an old aggravation. The rear wheel tapered sleeves on the left wheel are stuck to the wheel and axle. And I mean STUCK stuck. I loosened the three bolts, and tightened both jackscrews to the maximum. In fact I was so enthusiastic I twisted the head off one of the jackscrews!
And yet it's still wedged tight. I actually spent several hours (years ago) bush hogging and driving it around with the screws loose, and it never did come apart. After years of more rust-in-place, I doubt it's any looser now.
How do I get it loose without sledging a pipe slipped over the axle (that's hard on the internal axle bearings) or using explosives? I've never seen one stuck so hard. One adjusting pinion on my 70D was frozen solid in the casting, but the wedges still came out as designed...
Thanks
Charles
Thanks
Charles
