2630 tractor
R Bruce
I just pulled the hydraulic coupler drive off 2630 ( it was rattling) and discovered one of the studs on the crankshaft pulley is broken...looks like I'd have to pull the radiator at least to get to that pulley, anyone have any experience with this?
Thanks in advance
That is not uncommon for that family of engines. I have a 2510 that did the same thing a year or two ago. I tore it down expecting to find bad pump coupler bushing and found a loose stud that ate out the pulley. The 2510 engine is the same family as yours 202,219,239,276 ect. There are aftermarket pulleys available or you could just pick up a used one but check the belt groove for wear as they can be noisy if worn to bad. Tom
