JD 2555 Hi-lo issue-ing oil
riveroadrat
Looked into the rockshaft fill hole. I have a steady stream of oil dropping from right rockshaft just a little forward of it. The flow stops when I shut it down. I havent put the gauges on it yet. Johndeare720 quote-- I eliminated the hi-lo on my 2640. Very satisfied with tractor now. Took guts out of hi-lo unit and replaced input shaft with a non hi-lo shaft. Took some work to make sure there was a workable seal on the input shaft but worth the effort. Didn't know there was a kit but I think I have less than $250 in it. Has several hundred successful hours on it since. What does (Took some work to make sure there was a workable seal on the input shaft but worth the effort.) mean. Comments anyone?
Loosen the 2 bolts holding scv bracket to final drive housing then remove hose between scv & RS housing. With scv lever in neutral start engine no oil should exit where hose was connected. If no oil where hose was then RS valve seals are the problem
Hi-lo unit didn't have anything to do with rockshaft oil fountain. That sounds more like piston seal or o-rings in
control valve. The sealing issue i had with removing the hi-lo unit was to keep the oil in the transmission housing
from leaking into the extension housing and clutch around the input shaft. The hi-lo unit seals the input shaft
internally in the planetary housing of the unit. Since i eliminated all the guts of the planetary I had to have another
way to seal the input shaft. I don't have a good way to post diagrams but if memory serves me there was a location in
the extension housing to put a seal and I just determined where the input shaft lined up with that area and put it in
the lathe and made it round and smooth in that spot. Then looked up a seal by OD/ID to fit that spot. Lots of info but
nothing related to your issue. I also had a steady spray of oil in rockshaft housing when lift was up and lift would
drop when shut tractor off. Piston seal was literally gone on the bottom 1/3 of the piston.
Mine doesnt leak down when shut off. Thanks all for the reply. Tx Jim, no oil coming out good or no oil bad?
(quoted from post at 11:34:41 09/19/17)
Is that loosen couplers at rear or remote valves controlled from cab and which valve. Trying to get it straight in my head.
The fact that your tractor has a cab makes accessing scv return line to RS housing more of a challenge.I'm guessing your tractor has poppet valve type scv's. You can loosen banjo fitting(encircled in red) then with levers in neutral no oil should exit loose fitting when engine is started
