1947 JD B Late Model PTO packing
jdbuff
Can anyone tell where to buy packing for the PTO shaft. The JD parts book says that it takes two pieces of packing per shaft. JD part#
A2436R. Can it be ordered from a regular JD equipment dealer?
Those packing pieces look like over sized garden hose washers. You need to remove the rock shaft housing in order to remove a snap ring on the front end of the pto shaft. IIRC the valve box needs to come off too so you can reach the rest of the parts that make up the seal assembly.
Kent,
He's talking about the spring loaded packing on the pto shaft inside the hyd reservoir where the shaft goes through the front side of the rockshaft housing.
