My 50 has had a cracked exhaust manifold (by the hot/cold valve) for a long time, but while sitting in the barn for several years the rust got much worse and chunks have come off. The left cylinder is putting more exhaust out the hole than to the muffler! Time to replace the manifold.
The fasteners appear to be bolts instead of studs/nuts so I'm hoping at some time in the last 60+ years someone changed it already... maybe they'll come out and not break off. Ya, sure.
After reading the service manual it appears that it may be easier to pull the head and THEN separate the manifolds from the head. I'm sure the guides are shot too (big puff of blue smoke when opening the throttle after coasting). Not interested in doing pistons & rings, but I'm willing to do a valve job if the head's going to be off anyway.
Thoughts?
thanks.
Charles
Thoughts?
thanks.
Charles
