On the late graders 570B, 670B, 770B that were still using the 8 speeds PS, Deere added this valve at the end of the accumulators.
What is the benefits of this? Would a 4620 benefits from having this? I have the opportunity to buy this plate from a 570B at a salvage yard, and I wander if this would benefits a 4620 that is a fairly rude ride.
Deere also added a C1-C2 modulator assembly, on the 670B and 770B to 772BH, behind the clutch valve. This would requires to redo the routing of the main hydraulic lines from the hydraulic filte, but again, what is the benefit of this appendix?
To be noted that 772BH is last application of the 8 speeds PS and Deere HFWD, in about 1994!
