Re: 4020-- Is this one a diamond in the rough, or ?????
tomstractorsandtoys
If it has set for a long time there is something in the pumps that gets stuck. So you may have to take your pump to a shop to get it going. You are not going to hurt anything by trying first. We pulled a 404 out of an early 7700 combine that had not ran in 10 years and we could not get fuel out of the pump. Local shop did the pump and she fired right up. Tom
Since it doesn't run I doubt you unloaded it just to weight it only. So you must be weighing the truck,trailer and tractor and all to get to 24,200 lbs. which seems right ?
