TractorLinks.com
Show Parts for Model:
Lead washers on JD D (1or 2)
golfcartman
09-14-2017 04:37:24
Getting ready to replace the head after 4 new valves installed and was not sure on the lead washers. I've heard one and I've heard 2. What is the correct amount is my question. My manuals don't say. Thanks for your help.
John Deere D
09-14-2017 17:51:22
 Re: Lead washers on JD D (1or 2) in reply to golfcartman, 09-14-2017 04:37:24
I use ONE LEAD WASHER per Head Stud under each Nut.
I use only PARTS LIST PL-RDl-7-46
JD Styled Tractors S # 143800 AND UP:
Item # 14..Ref.No. AD 1769 R Lead Washer (9 USED) (Box of 50):
Head Nuts are torqued to 208 FT-Lbs.:
I use ONE Lead washer per Head Stud:
What ever you decide on good luck:
Bob....Owner operator of several Styled JD D's
Mike M
09-15-2017 05:12:08
 Re: Lead washers on JD D (1or 2) in reply to John Deere D, 09-14-2017 17:51:22
So one or the other of those parts lists has a misprint ?
The one that called for 18 (2 per stud) seemed odd as every other Deere book seems to call out 1 per stud as I recall, and you usually get plenty to trim off.
Mike M
09-14-2017 05:59:01
That does seem strange the D parts book calls for 2 per stud ? I guess the D's larger studs must have larger gaps to fill ? So like the book says 2 per stud for a total of 18. The extra will just squish out anyhow. Just trim the excess off after they are torqued down.
Bob
09-14-2017 04:58:52
Both parts catalogs, PC658 (unstyled), and PC659 (styled), show 18 lead washers per head, along with 9 studs and 9 nuts, so it looks like "2" is the number of lead washers per stud.!
