jd 60 clutch issue
tomnwoh
i am installing a new clutch on my jd 60 . after reading on a previous post it appears that my drive gear has moved on the belt pulley . what is the proper procedure to put it back in place
Might be, but that is really un-likely...
That gear is installed with PLENTY Pressure and they seldom move..
If you are replacing the Clutch Drum, maybe the replacement you have is not the same..??
