John Nessler
New User
Hi,
My father and I use our old b to plant food plots for deer. I've got an odd issue when pulling discs or our cultipacker.
Say when we are going up a slight grade and the load increases the governor opens the throttle and it runs fine, but when reaching the top of the grade and the load lessens, the tractor surges for a bit. The governor is opening and closing the throttle plate causing this issue. If I close the load adjustment a few clicks this gets better, but then the throttle response is terrible and it coughs when opening the throttle. I'm thinking the idle adjustment may be lean. I'm away from the property right now so I can test it right now. Any thoughts?
Thanks
Thanks
