3010 splitting
craigco
Should be able to split the diesel 3010 this weekend to replace PTO pin. Should I get the transmission in neutral before I undo the linkage? We will most likely roll the rear back.
You will be able to shift it with the linkage unhooked,, take note of where the linkages is at when you are in the "Tow" position,,it will roll better there..
