I have a 4250 myself along with all the technical manuals. It calls out a
AR64422 turn signal controller, about $60.
I am working on a 4055, flashers work but turn signal does not. The parts book calls out a RE53109 which is a simple rotary switch with a connector with it, $128. I will replace this part tomorrow.
I do not have the 55 series technical manual. I am guessing this flasher/switch circuit changed from the 50 to the 55 series. The 50 series looks like one module that contains both the flasher and switch. The 55 series seems to have gone to separate flasher and turn signal switch components although I am not seeing a separate parts call out for a flasher on the 55 series.
Can someone tell me where the flasher is on the 55 series or give me any information on the differences on this circuit between the 50 and 55 series?
Thanks.
Paul
Thanks.
Paul
