JD400 hoe/loader brake valve removal
ctsklrich
New User
no brake pedal but check valves and seals are OK. Suspect the plug in the equalizer gallery has pushed out because fluid is being pumped out but cant see where it goes. Need advise for removing valve where it bolts to reverser valve. Uses 2 studs and I cant remove the studs as they hit the frame of loader. Do I have to remove reverser valve to get brake valve off (ughh) Any help apprechiated
