4440 won't start
Novgto
New User
My friends 4440 has stopped running. We opened a line on the injector and cranked the engine. We got some fuel out of the injector. It didn't start. I noticed that it was cranking really fast. Is that a problem with the injection pump? Or does it maybe have other problems? I would appreciate any ideas and Thankyou Jeff
Prove the fuel supply to and from the pumps ....be sure the stop lever is in the on position,,cable could have moved in the holder...
(quoted from post at 03:12:33 09/09/17)
I'll add to what Tim stated it's possible transfer pump that's attached to inj pump has failed. Is fuel cap still venting?
Or peessure relief valve in banjo fitting at injection pump stuck open?
