Check with Jim at Agri Services in New York. I believe its www.wiringharnesses.com or else try NAPA
On a Class A Charging System (Polarize BEFORE start up) if when running if you ground out the Gennys FLD post she charges then but NOT otherwise I suspect the VR is bad or not well grounded. However if no charge even with FLD grounded I suspect the genny is bad if all eose is right and shes wired correct.
John T
John T
