JOHN DEERE 4020 HYDRAULIC ISSUES
TEXASJD4020
New User
i have a 1966 John Deere 4020 PS diesel the tractro starts easy and runs well. the hydraulics work in D only. if i select L or LD no hydraulics at all but in D the 3 point raises and lowers quickly. the FEL works if i manipulate the levers in a specific sequence (eg scv lever forward + loader lever back = loader raises , scv lever back + loader lever forward = loader lowers). Power steering and brakes perform flawless no trouble whatsoever. trans temp rises after 3 hours or so of brushhogging what could cause this
The load and depth control lever only affects the three point
but you might have a plug screen or filter that's causing your
other hydraulic pump problems which would affect your three
point also
L/D mechanism needs to be adjusted following the steps outlined in JD tech manual. It also sounds as if SCV needs attention & it's valves set to spec's as FEL should operate correctly with scv lever in either forward or rearward position but not both positions. I will suggest to attach loader hyd's directly to tractor hyd's freeing scv's for other purposes.
The rockshaft housings have a square 4 bolt plate on the bottom that is commonly broken. Can remove the load control arm adjustment plug and see it spraying oil internaly using a small flash light.
(quoted from post at 08:12:10 09/06/17)
I doubt if the plate you refer to is leaking 3 pt would operate correctly in "D".
(quoted from post at 06:23:31 09/06/17)
Yeh...you are right I re-read the original post and paid attention. It would seem the selective control valve is leaking internally(or three-point valve)....
(quoted from post at 22:33:33 09/05/17) The load and depth control lever only affects the three point
point also
i thought the depth control lever controlled just the 3 point.
i changed the fluids and filters and cleaned the sump screen a few months ago
thank you
