Mnethercutt
Planning on testing my bearing clearances with plastiguage. I have semi-low oil pressure (20 psi when hot, 60 when cool) and want to figure out if it's a pump issue (I have no shims in the spring in the pump piston, and it may have the wrong spring e.e). There is no knock of any kind in the motor. Just looking for any tips when using plasti guage. I'm not planning on removing the block. Is that possible? I'd think you could check the conrod clearance ok with the engine on, but can you check the mains clearance with the engine still in the tractor?
Any tips on this appreciated
