So, I've been reading up on the R being Bored to 6 1/8" and putting in either 730 or 830 Pistons. Since I will most likely have to Bore my block, I believe this is the direction I'll be going.
What I've also seen is that you need to put the 730 or 830 injectors in it as well. Is this Absolutely necessary?? Or can you make it happen with the R Injectors? I'd like to know any success/failure stories of both if anyone has any.
Oh, and when using the 730/830 injectors... would you need the injector pump with it??
