JD 620 power steering thrust bearing cross referance ?
Jo Bird
Looking for a cross reference for JD 7679, New Departure E 30213 A thrust ball bearing from the JD 620 power steering pedestal. Does any one have a number for one they have used ??
Jo
Here's a cross reference I've used
http://www.autopartoo.com/oem/partscrossinterchange/jd7679
Google the part number and you can get all sorts of suppliers and prices. I used one of the F.A.G. numbers and found one for $70. Don't know anything about the supplier or the bearing.
https://www.123bearing.com/bearing-7213-B-TVP-FAG.php
Good luck!
Brandon
That bearing is a special thrust bearing and it does not have a cage on the balls in it. The new bearing will go in one direction to support the weight.
Thank you to all whom replied. Going with a VXB 7213B, it's supposed to be of equal quality to the New Departure E 30213 A, only time will tell how it works out, thanks again.
JO
