Loadshaft seal 3010
craigco
Have to do the loadshaft seals on the propane 3010. Did them on the diesel but can't remember where to put the selector for depth control. I think it was D is this correct?
(quoted from post at 20:34:12 09/04/17) I am curious, would think in L, the flex of the shaft would not be sensed?
It is the other way. In L, the rockshaft position control lever contacts the " repartition cam " at the bottom, so the rockshaft position has a little effect on the control of the rockshaft valves and the load arm has a bigger effect.
The repartition cam is the one resting on top on the rockshaft position cam, and at the bottom on the Load sensing arm.
