Northvale PA
on an earlier post, I explained how I replaced the internal PTO shaft pin, that had sheared when the cap screws on the 540 spline stub shaft came loose while mowing hay. I did not split the tractor. As it turns out, there is a 3/4" pipe plug in the right side of the transmission. I drained out the fluid, pulled the plug and I could see exactly where the pin can be inserted. The hole must have been drilled and tapped by a mechanic who knew where the pin was, from other work. Working thru the hole, I replaced the $2 pin. Pretty simple actually. Good luck all and thanks to whoever figured this out. By the way, I live in York County, PA. The tractor came from the Cuba City, WI area, according to a sticker on the hood.
