670 size bush hog
I'd say 4-ft max on the cutter and maybe a 5-footer for the finish mower as long as you don't try to mow anything too wild. From what I can tell your tractor has an 18 hp engine. My sub-compact has a 23 hp engine and a 5-ft mower deck gives it a good load in heavy, lush grass. The 670's gear transmission will save some power compared to my hydro but at the same time it makes it harder to adjust your speed to accommodate varying conditions so you want to have enough reserve power to get you through the tougher spots without having to stop and downshift a lot.
BV: I've had a 670 4x4 and I can assure you it's not much of a mowing tractor....has about 18 h.p. and max you could use would be a 4' rotary mower and probably a 4' finish mower. You weight of implement to tractor is very high ratio and not sutible on uneven ground. The did come out with a belly mower on some unit primarily the 2 wheel drive models. My advise would be to buy a 4' finish mower rear mounted. I went up to the 770 and 790 for the 5' models....I was never impressed with the 670 but it would have been good with a front end loader and backhoe to use in city work....
