Ben.So.Tex
I bought a mag from a fellow that said it was good, ,I took the mag off my tractor, I took the New mag put in a vise to check it for fire, well I could turn the mag forward and backward 360+ and it would not click and it had NO resistance, Took the mag out of the vise turned it over and spun it by hand and it would then Click, Good, put it in the tractor and it sound like it had a weak click and no fire. .. Took it out. ..Checked my mag and it would spin 360 forward and backward with no resistance, I took it turned over and it then got resistance and a good click,, Put back in the tractor. Rotated the mag forward and the set the flywheel at the 3 o'clock mark, rotated the mag backward till it click, That should be in perfect Time. . But now it has no fire, Why? it ran the tractor 30 minutes before. . Is it possible that it could be out of time internally? .Both mag are type C.
