I have a 430, in the middle of moving and my manuals are packed. Where do I check the trans/axle fluid and 3 point hitch fluid? I'm assuming the upper one and lower ones are fill points.
Thanks
transmision oil is a pipe plug just behind the RH foot rest on axle housing. Kind of in the corner there. Should be up to plug. Hydraulic oil check it a petcock on the front of the touchomatic housing, just below the seat. Fill for it is breather cap under the seat. That is on my 430U, I am not sure if other models may have the petcock on the back of the housing.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Where do I check the trans/axle fluid and 3 point hitch fluid?[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the [b:654c4848f0]TRANSMISSION HOUSING AND ASSOCIATED PARTS[/b:654c4848f0] diagram below.
a170743.jpg" width="650"
Note the square head pipe plug (Key 19).
Take a look at the transmission filler plug on "BW" our Model 40T.
a170744.jpg" width="650"
Fill to bottom of threads.
Take a look at the [b:654c4848f0]TOUCH-O-MATIC ROCKSHAFT ASSEMBLY[/b:654c4848f0] diagram below.
a170745.jpg" width="650"
Note the drain cock (Key 43).
Take a look at the test cock on "BW" our Model 40T.
a170746.jpg" width="650"
Open the test cock.
If oil does not drip out, then add oil at the filler cap under the seat,
a170747.jpg" width="650"
Hope this helps.
Thanks, I figured that's where I added was questioning how full so that's what I was looking for. Just Hydraulic fluid in both?
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Just Hydraulic fluid in both?[/i:654c4848f0][/b:654c4848f0]</font>"
On our 40T, the operator's manual recommends 5 1/2 quarts of SAE 10W for the Touch-O-Matic.
The operator's manual recommends 7 1/2 quarts of SAE 90 for the transmission.
We use GL 140 in the transmissions of all our vintage tractors.
Hope this helps.
