Runningranch
New User
After replacing my sleeves, and replacing all of the old nasty gas in the tank, my 2510 would not run for more than a few seconds. I found that the fuel pump was not pumping. Replaced it and got good flow. It started but wasn't running quite right. I ordered a carb kit and soaked all of the carb parts in cleaner and shot carb cleaner through all openings. Put the carb on and it ran awesome, for a few hours. It started running really rich and would barley run. Too off the carb and there was rust built up between the float and fuel bowl preventing the float from working. Cleaaned again and it ran good for a bit then I didn't use it for a few weeks. Went to start it and it will only stayrunning while the choke is full on. Any thoughts? It has a new fuel filter too.
Thanks
Chris
Thanks
Chris
