There is a metal piece up inside the rotor where it goes onto the shaft. You may have lost that when you pulled the rotor off. Some
Times they will fall out. Won't work properly with out that . It will ruin the contacts in the cap also. Just had the same issue on my D.
Many times one of the "legs" on that metal insert has broken off. I used to be able to buy just that metal piece from JD and kept them on hand.
